Any soundcards with delay?
Discussion in 'Computer Components' started by ilkand, Jul 23, 2003.
  1. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    As title really. Are there any soundcards that can add a delay to multichannel sound like with some receivers do? To avoid lipsync.
    Andrew
  2. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Yes. You can add per channel delay in the drivers of some cards (M-Audio come to mind) or software filters such as AC3Filter.
    MuFu.
  3. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    I tried AC3filter and was very impressed, but it is only 5.1 and the author has no wish to go to 7.1., which I would like.
    Which m-audio cards have channel delay? i had a revo, but it only allowed you to set speaker distances, and this was not enough to overcome the sort of lipsync you can get with dscaler.
    Will have a look at the maudio site.
    Andrew
  4. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Ok - yes I was thinking of "spoofing" delay using the speaker distance sliders.
    MuFu.
  5. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    I know - just sit much further away from the speakers to increase the delay by the desired amount ;)
