Any software upgrade Denon 3910?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Barend, Nov 13, 2004.
  1. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Any yet?
    There are a few quirks I love to see corrected...
    Like the funny way it demands a sacd/dvd disc to be ejected when you want to twiddle the settings...the Pio dv868 just interrupted...
    And maybe some timing options for hdmi-PAL, so I can AT LAST feed my Panny plasma with a correct signal!
    Yeah I know, yuv is very good too, but you see I bought this dvi board...
    Barend
  2. awhb
    awhb
    Hi Barend, what's the problem with 3910 feeding HDMI to a plasma? I have a Pio 434 and am deciding on an upgrade for my 757Ai.
    Thanks.
  3. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Don't think you'll have a problem with a Pio Plasma, it's specific to the poor PAL support by the Panny dvi board.
    Good think abt the 3910 over the 868 is that the Denon recalculates to ntsc, where the 868 just doesn't work PAL into the Panny at all...mixed blessing though since this leads to less PQ because the yuv o/p of the 3910 is very very good- better than the 868 (hdmi/dvi of the 868 is excellent though, AFAI could see it with my 3 ntsc discs...).
    I'm happy with my 3910 since the PQ is razor sharp & very clean even on sat reception!
    Barend
  4. JetJockey
    JetJockey
    Errr?
    Sorry Barend, you got me there.
    How do you mean that Sat picture is razor sharp through the 3910?? Do you put your Sky picture through your DVD player? :confused:
    Gerald.
  5. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Havent panasonic just released the HDMI blade now?
    Also i think a firware is due, well soon
