Hi, I use a wood burner with a back boiler to do heat my central heating, it doesn't have a massive output compared to a gas boiler but eventually gets there after running all evening. What I would like if for it to initially heat 2 rooms first and once they reach their desired temperature then start heating others rooms and so on whilst maintaining the first rooms. currently the whole system is on normal thermostatic valves but that means as every room is below the desired temperature at the start it is trying to heat everything.
From what I can see most systems such as Tado only allow control by temperature and time so you set a room to be at a specific temperature over set hours, using that system would end up being very similar to normal thermostatic valves as it will still heat all the rooms Unless I only have the initial rooms being turned on the problem here would be once they warm up I would have to keep checking then manually set other rooms to do the same. If there was a system that allows priority of opening up new rooms as others reach set levels it would make the system much more useful in this specific use although I realise this is a very unusual need so is unlikely to exist.
If anyone has any ideas on if this system exists that would be amazing as I have been going round in circles looking at details but not getting anywhere yet. I cant just have standard times for each room to join as it all depends on what time the fire is lit, how cold it is outside and how hot the fire is burnt.
Thans
Thans
