Any Scart for RGB
Discussion in 'Cables & Switches' started by Toyotasupra, Jun 8, 2005.
  1. Toyotasupra
    Toyotasupra
    Mar 13, 2005
    471
    Peacehaven, East Sussex
    +23
    Hi all,
    I have a Sony FV32FQ86U and a Pioneer DV535 DVD player with RGB output.
    The totalshield ofc scart lead I have I believe is working fine in RGB but can anyone tell me if I need a special scart for RGB?
    Also as a side note if anyone else has this tv do you think the picture is better with RGB or S-Video?
    Thanks :thumbsup:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    As long as your scart lead is fully wired then it will work with RGBcvS signals. A few of the very cheap scart leads only have composite & stereo audio connected. Some scarts are labelled as RGB scart and these normally only have the RGBcvS pins with no audio connections.
    A fully wired scart will also be able to carry S-Video, so you can switch between RGBcvS & S-Video to see which you think looks better.
    Mark.
