Any Samsung TV engineers on here?
Discussion in 'Samsung TVs Forum' started by Slider09, Jan 24, 2008.
Tags:
  1. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    I am currently on my 4th M87, current one has severe scart banding on EXT2 and faint banding on EXT1.
    I am getting sick and tired of taking it back. Is there a possible fix for this banding?
    TIA
  2. mcjibba
    mcjibba
    Mar 3, 2007
    367
    London
    +49
    What are you connecting up? Are you using decent scart cables or the poorly shielded ones that come bundled with most equipment?
  3. Mr-Bananas
    Mr-Bananas
    Apr 3, 2006
    2,508
    +397
    From my experience with TV engineers, you would would probably get more help asking a Chimp at your local Zoo.
  4. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    I am using a Thor 1.5m scart cable between Sky+ and TV. It's not the cable, it's the tv.
  5. Pootle_Flump
    Pootle_Flump
    Jan 2, 2008
    26
    3
    I have a very LE40M87 recent set, and the same problems. It's common on these panels - search the LE40M87 thread.
    No fix I'm afraid.
  6. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    I know it's a common problem, just wanted to know if Samsung engineers knew about the issue and any possible fix in the pipeline?
  7. Sly Fly
    Sly Fly
    Nov 23, 2004
    2,010
    116
    +726
    Someone did post a picture of a possible fix. It's a while since I last looked at the M86/M87 thread (as I purchased a V3000 instead) but I still think it's there. You'll have to go back a few pages I reckon.
    All he did was fix a tie-wire thing to the back of the TV to re-direct the scart cabling away from a certain area that he said caused the banding. He posted a pic of what he'd done and said it either eliminated or reduced the banding.
    Hope this helps.
  8. mcjibba
    mcjibba
    Mar 3, 2007
    367
    London
    +49
    That was me :rotfl:
    Link is here
    http://www.avforums.com/forums/showpost.php?p=6040067&postcount=10692
    I found that by using the cable tie(already on back of the set) reduced the scart interference quite well.
    I dont think its the fault of the LCD as this kind of thing is well reported problem with many Sky boxes and TV's regardless of the make.
  9. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    Thanks for the link. I already use the cable tie on the back of the tv to tie back all the cables, apart from the power cord. Don't want the power cord close to the scart cable. I currently use a Thor scart, so not a cheapie one. It is not just the Sky though causing interference. If I connect either the Nintendo Wii or my DVD recorder upto the EXT2 the picture is truely awful.
    If there is no possible fix I may take it back (again, this is my 4th set).
  10. mcjibba
    mcjibba
    Mar 3, 2007
    367
    London
    +49
    It is the power cable that you need to route. Try that and see what happens. The idea is to keep the power cable away from the sockets cable to cable interference is not going to happen as the cables are sufficently insulated.
  11. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    How is keeping the power cable next to the scart cable going to improve the interference?
  12. number_3
    number_3
    Mar 8, 2006
    437
    +22
    does this still happen with this TV if your feeding it via Hdmi cables
    from your Sat/Cable box & DVD player..??
    Mark
  13. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    No, the interference is a scart issue.
  14. number_3
    number_3
    Mar 8, 2006
    437
    +22
    thanks for the update Gazz.
    Mark
  15. Hopalong
    Hopalong
    Jan 11, 2008
    337
    aberdeen
    +21
    Hi i have the same thing(banding waves moving down the screen) on my tv le40m87 i recently bought a qed 2110 scart cable thinking that would solve it but it hasnt.I dont always notice it though it doesnt seem to happen on every channel (sky+).
    does this mean my tvs faulty or is this just something you have to live with on this tv with SD via a scart cable?
  16. sn42or
    sn42or
    Oct 6, 2007
    20
    Lingfield Surrey
    Hello,
    Still confused, pictures posted by mcjibba show both power lead and scart lead tied together by the TV's cable tie. Is this correct?/has anyone actually tried this?
    I am not an expert but would have thought these leads should be kept apart to stop the banding. Should the power lead or even the scart lead by held by the tie individually. Which one???
    Please confirm what you have done and whether this has been sucessful.
    Steve
  17. sn42or
    sn42or
    Oct 6, 2007
    20
    Lingfield Surrey
    Hello,
    Anyone help
    This scart issue is driving me mad
    thanks
  18. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    Firmware 2013 apparently fixes it
  19. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    If you look on the dedicated ME4087/86 thread (apologies - I don't know how to post links) there's some debate going on about this issue (amongst others!) - there is a train of thought that a firmware upgrade to 2013 will fix the problem. Interestingly, when I rang Samsung about this, the fool I spoke to on the phone denied any existance of firmware 2013, or 2012 for that matter - even though I've checked my TV and I have 2012!!!
    I've been experiencing the banding since I got the set last month, and any time now I'm expecting an engineer to come round and have a look.
    I'll reprt back after the weekend with the results...
  20. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    Hi, look forward to the update. I too have scart banding, EXT2 is unwatchable, EXT1 seems to get better the longer the TV is on. I bought my M87 back in January, think I am on firmware 2012 as well.
    Ironic really, this is my 4th M87, previous 3 did not suffer from banding, just had other issues!!!
  21. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    Right - just got home and had a quick test of the TV - I can happily confirm that the firware upgrade HAS sorted out the issue.
    Previously I had firware 2012 and when watching Sky+ through RGB SCART on Ext1 the banding was quite prominent. Now, following the engineers visit, I am on firware 2013, and the same scenes on Sky+ that previously showed the banding, are now flawless. Absolutely nothing else has changed in my setup, so it has to be the firmware that solves the issue.
    Unfortunately I don't use Ext 2 so I can't confirm that the banding was there before, but it certainly isn't now.
    A word of advice though - if you ring Samsung to request this upgrade they might try to deny there's anything wrong or the upgrade will work - persevere and hopefully the engineer that comes out will be as clued up as the one we had and your problem should be fixed.
    Dave
  22. rmccardal
    rmccardal
    Mar 20, 2006
    54
    Hi, can you tell me what panel you have ? I'm only asking as I am running 2012 on a samsung panel (according to the label) and have no issues at all watching sky via ext1 or 2!!
    I'm guessing I should not bother with any firmware update following the "if it ain't broke, don't fix it" method.
  23. Daverey2
    Daverey2
    Nov 12, 2004
    155
    Cheshire
    +18
    if you'll excuse my ignorance - how do I know what panel I have?
  24. Yemeth
    Yemeth
    Jun 5, 2007
    5,102
    Hedeby Island
    +993
    Back sticker of the tv. All the way to the right of the line that contains the model code LE##M8#BD [R]. Its after the [R]. Either C, S or A is the letter you are looking for.
  25. Slider09
    Slider09
    Jun 27, 2007
    608
    +23
    Got Samsung coming out the Tuesday after easter. Hopefully update the firmware to cure the banding.
  26. chef shoes
    chef shoes
    Mar 24, 2008
    euxton, lancs
    hello
    first thread and all that.. :)
    ive had the lines across the screen since i got it but tried to live with it blaming the sky box and alsorts, didnt realise i wasnt the only one
    phone samsung up today (bought in august) and they are organising a replacement tv to be sent out
    hope it has this new firmware they speak of
    btw how does the firmware get installed on the tv?
