Any "relatively" cheap HDMI out DVD players/recorders?
Discussion in 'Blu-ray & DVD Players & Recorders' started by carefactornil, Jul 4, 2005.
  1. carefactornil
    carefactornil
    Feb 19, 2001
    190
    16
    UK
    I'm going to be getting the Pio 505XDE and therefore probably Sky's HD service at some point. When the new format DVDs (Blu-ray or whatever) come out and that market is stable I'll probably get a new DVD player that's compatible for that.
    So I want something that I will probably only have for a couple of years (starting from scratch). Seeing as I'm getting the 505XDE I was thinking I might get a DVD player/recorder with HDMI out for the benefit that gives. So forget things like Pioneer's 920 as that's too expensive for a couple of years. Ideally I would like a hard disk to record onto (even if it's smallish) until I get the Sky HD as I don't have Sky+ and probably won't bother getting it until HD is out fully. So I'm a bit torn between getting a HDMI out dedicated player only or something that doesn't have HDMI out but does have a hard disk. I'm assuming that there isn't a cheapish solution that does both out now?! (I'm looking at £500 max.
    Someone mentioned a Samsung (don't know model) and possibly Denon (2910, 3910?) as possibilities. Any thoughts? :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Pio 668? denon 2910?
  3. carefactornil
    carefactornil
    Feb 19, 2001
    190
    16
    UK
    Thanks Horny.
    OK - those seem to be approaching the £500 mark.
    Originally I'd looked at a player/HDD combo such as the Pioneer 420 which has 80G HDD plus it can record DVDs (not essential for me but a nice to have). The price of that is around £275.
    Do you or does anyone think the difference in price (nearly double) is worth it in terms of picture/HDMI? It seems a lot of extra £ for purely a DVD player. I will test various ones against the 505XDE soon but I'd be interested to hear what people think first, especially bearing in mind it's only a stop-gap for a year or so.
