any recorders that playback via rf lead
Discussion in 'Blu-ray & DVD Players & Recorders' started by raykoko, Aug 14, 2005.
  1. raykoko
    raykoko
    Mar 3, 2005
    1,131
    38
    Notts
    +11
    looking for one that i can view on teles in different rooms
    have only seen DVD recorders that play thru scart
  2. mh123
    mh123
    Apr 2, 2005
    686
    Offshore UK
    +66
    Thought about using a video sender?
    Much better quality picture & audio than sending via RF. A simple setup shouldn't cost more than £50 and you can add multiple receivers if necessary.
  3. JayCee
    JayCee
    Jan 20, 2004
    20,229
    Lanarkshire
    +1,937
    To playback via the RF Out requires the DVDR to have an RF Modulator.
    AFAIK the only brand to have this (although it is switched off by default) are some Panasonic models.
  4. DVD-RAM
    DVD-RAM
    The Panasonic E50 has this feature. To initiate it, you have to press and hold the 'FUNCTION' button, and then enter the required RF O/P channel number. Then program (say) channel6 on your TV to match.
    **EDIT**
    Also works on E55, just checked.
  5. raykoko
    raykoko
    Mar 3, 2005
    1,131
    38
    Notts
    +11
    thnx for all the info, will look into the panasonic
    would like to stick with rf as already cabled around the house with good picture/sound
    sorry, forgot to mention i was looking for one with a harddrive as well
  6. andye2004
    andye2004
    Sep 11, 2004
    689
    28
    +31
    I think it can be done with Tosh rdxs34 also.
  7. JayCee
    JayCee
    Jan 20, 2004
    20,229
    Lanarkshire
    +1,937
    No it can't.
    The UK model does not have an RF modulator.
  8. andye2004
    andye2004
    Sep 11, 2004
    689
    28
    +31
    I stand corrected! You're quite right of course.
  9. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Whilst this is a convenient solution and I do it myself with sky and plan to do it with my panasonic recorder when I get round to sorting out the connections, you do not get good sound as of course it is in mono not stereo, as the recorder does not have a nicam encoder.
  10. raykoko
    raykoko
    Mar 3, 2005
    1,131
    38
    Notts
    +11
    i can live with mono if i can get the signal to where i need it
  11. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I just plug mine into my old video recorder which has a tuner mode (so it doesn't auto switch off) and use its modulator..
