Any recomendation for Component Cables
Discussion in 'Projectors, Screens & Video Processors' started by yatesd2404, Jun 2, 2003.
  1. yatesd2404
    yatesd2404
    Not sure if this should be in this forum or not but here goes.
    I wondered if anyone would have a recommendation for a component cable to connect up a Sharp PJ to an Arcam DVD player for prog scan.
    I know it depends on money. I have read that tha Supra one is quite good, and would probs spend around 100 pounds.
    Anyone any thoughts??
    Thanks,
    Dave.
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    www.intoav.com
    sell very good Comp cable for the money.
    Ask for the evolution quality. I have it. Very robust, well shielded with quality inter-connects at either end.
    Hope this helps.
    Cap.:clap:
  3. juboy
    juboy
    I used to use a Supra AV3 component cable, which was pretty good.
    Recently swapped that out for a set of Scorpion Cables component cables and was mightily impressed with the results. Far better colour saturation and definition and more clarity to the image.
    The Scorpion Cables really look and feel like you've got your money's worth too. Highly recommended.
  4. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    I wanted 4m long cables so made my own.
    Used some colour coded Van Damme coax from maplin, silver soldered to standard Eichmann bullet plugs from Hi Fi cables
    There was a simple but slightly irritating soldering session to complete the cables.
    The cost was about £70 and the picture quality is excellent, though I haven't compared them directly with any ready made cables.
  5. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Three of these from Farnell would do the trick nicely, and very inexpensive even for 10m cables.......
    Sean G.
