Any reccomendations for US Voltage convertors for pj's
Discussion in 'Projectors, Screens & Video Processors' started by dannyc, Jan 22, 2004.
  1. dannyc
    dannyc
    Has anyone been using a UK-US voltage convertor to power 110V gear here in the UK? I think most projectors need more watts than the cheap convertors that you get in Maplins. The only things I have seen are the Isotek Qube for mega$$$ or a draper industrial convertor for machine tools.
    Any better ideas?
    Dan
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    What's the power of your projector lamp ?
  3. kbfern
    kbfern
    Aug 17, 2002
    17,799
    Wolverhampton
    +5,960
    Maplin do 100w 200w 450w and 550w (550w @£69) 550w should be more than enough.
  4. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Dan,
    Are you importing one of these by any chance :) :)
    Lamp is 420W, 660W total, so I would look for maybe an 800w or more transformer.
    How about one of those yellow isolation transformers as used on building sites?
    Somewhere must do one for 220 to 110V at maybe 800W or more ?
    Good luck
    Mark.
  5. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    I have a 1000w 240v to 110v transformer that I used for a US spec crt projector that I had but now no longer require it. No more than about 30 hours use.
    I forget the price (I think it was about £90). Happy to let it go if you want - pm if me interested (not sure if this breaks the advertising rules though - mod's delete if need be). Can take a piccie if need be, its big and white is about the best description of it!
    Paul
  6. dannyc
    dannyc
    Mark,
    You are very close there! actually its a G10 clone, hope to get it set up and calibrated soon.
    PaulB,
    I have just bought a industrial convertor, wish I had seen your post first, can you post a piccie anyway.
    cheers
    Dan
  7. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Sure, here ya go. Its likely the same type as you have just a different colour perhaps.
    Paul
  8. dannyc
    dannyc
    Yep, very similar but so much more attractive in White! not bright yellow. How much were you looking for anyway?
    Dan
  9. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Hi Danny,
    I'd probably be looking for £50. This would include postage which would be quite high due to the weight of the bugger (note to self - need to check if I still have the box!).
    Paul
  10. dannyc
    dannyc
    Quick question, does this have one or two sockets? and if it is 1000w max load what is its continuous rating?
    Dan
  11. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,765
    Outpost 31
    +211
    Two US sockets (one each side) and rated at 1000w but as to the continuous rating erm, pass. I'll need to dig out the box and see if the paperwork is still in there.
    Let me get back to you.
    Paul
