Any problems using Radeon VE and Power DVD 4?
Discussion in 'Desktop & Laptop Computers Forum' started by azzo, Jun 3, 2002.
  1. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    I am considering getting a Radeon VE as it has no fan. Seems great for HTPC. However I have read on the ATI site that the hardware acceleration does not work on PowerDVD 4.0.
    Is this true? I thought this would be the most likely combination for a HTPC use. Oh and I'll be using XP or W98.
    Many thanks.
    Azzo
  2. Guest
    I have a Radeon VE and use PowerDVD 4 with no probs, that said I dont use hardware acceleration. Just make sure your CPU is fast enough for the job, mine is a AMD Tbird 900Mhz and it works a treat.
  3. tk
    tk
    Feb 11, 2001
    19
    Any particular reason why not use hardware acceleration?
    H/W acceleration should give best results.
  4. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    The picture is different when not using hardware acceleration, some say it is better. I guess the programmers can tweak the picture somehow. Some people prefer hardware, some hardware.
    I have read on the ATI site that the hardware acceleration is only an issue with windows XP and Power DVD 4.0. I just thought it wierd that this combination is not used more on this forum. After all XP is the best OS for this sort of stuff and the Radeon VE cards are the best as they dont have fans.
    Azzo.
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    PowerDVDXP with DXVA (HW enabled) on does produce a much better PQ which is not hard to spot. However you do have to readjust the overlay settings otherwise the brightness is way too high (with Radeons anyway). The other issue is with video based sources, the software decoder (DXVA off) is much better at deinterlacing viideo based material, for most DVDs this isn't a problem.
  6. tk
    tk
    Feb 11, 2001
    19
    I have ATI, WIN XP and PDVD 4.0 XP and it is running just fine with H/W acceleration on.
  7. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    Typical, ATI support must be wrong.
    Thanx azzo
  8. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    ....Buit does it matter if you're running a "powered by ATI" Radeon rather than a genuine ATI one?
  9. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    It doesn't matter as long as you have the correct genuine driver.
  10. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I seem to recall having to flash the "powered by" card's bios to enable it to run the genuine driver - or am I going mad?
  11. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The 8500 Rage3d forum has details on how to install proper ATI drivers on powered by cards.
  12. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
  13. Guest
    I am getting a better picture without using hardware acceleration, the CPU works just fine. I was getting interlacing artifacts and colour bleed, so I turned it off.
