Any possibility for zooming in letterbox picture from PC with HS10/2???
Discussion in 'Projectors, Screens & Video Processors' started by sonn, Apr 25, 2003.
  1. sonn
    sonn
    Planned to buy SIC-HS30 interface cable for seeing DivX movies with my Sony VPL-HS2, but it seems that there are no ways for zooming the letterbox computer picture in either with HS10 or HS2. Is it really so? Any possible tricks? ('H Size' + computer settings? S-video card for PC?)
    cheers
    Sonn
  2. Kramer
    Kramer
    Yes, certain options are "disabled" when using a PC input to the HS10.
    Check out Zoomplayer (assuming it has DivX compatability - codecs etc...). If it does, it's problem solved.
    Shouldn't be too much of a problem I imagine - just depends on the DivX software features.
    :smoke:
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    Or you can use YXY with your existing player and do the same thing, though it's a bit clunky in comparison to Zoom Player.
    Gary.
  4. sonn
    sonn
    Thanks for the promising answers of yours!
    I was just confused, because having happened to read statements like that:
    "Actually, using a SIC-HS30 cable, it seems the HS10 is quite forgiving... I put through tons of resolutions (using the myHD to output VGA) from 480i, 480p, 768p, 720p through 1080i - and they all worked fine with the HS10 in computer mode - of course everything was in 4:3 aspect ratio!!!"
