nheather
My old Stuart Turner Monsoon shower pump is beginning to fail and I need to replace it.
Trouble is , I can't remember what type and pressure version it is.
Pretty sure it is a negative head type but no idea what pressure.
Is there anyway of telling - it is quite awkward to access it in situ and quite a few years ago a plumber did some work on it and forgot to replace the plastic cover - by the time I had noticed it and contacted him he could not find it, said that it had probably been thrown out with all the other waste. He did provide a replacement but it is generic - I fear that this plastic cover is the only place where model, version and serial number - bit silly if true having such details on a part so easily removed and indeed could be fitted to a different pump.
Anyway grasping at straws, here are some photos
I think the pressure vessel indicates that it is a negative head type.
It is a twin - hot and cold - I know that for certain
I have found the manual but this is common for 1.5Bar, 2.0Bar, 3.0Bar or 4.0Bar and I have no idea what pressure version it actually is.
UPDATE - I can rule out the 4.0Bar as that has a thermal circuit breaker and mine doesn't. I also don't think it is a 1.5Bar, so suspect it is a 2.0Bar or a 3.0Bar.
ANOTHER UPDATE - From the manual the length of the pump is different for each pressure version. Now assuming this is the total overall length, mine is matching the 3.0 Bar.
QUESTION - can you oversize - say it were a 2.0Bar but I have no way of knowing that so fit a 4.0Bar would there be any problem - or does it need to be properly sized for the solution.
Cheers,
Nigel
Cheers,
Nigel
