nheather
Outstanding Member
As a good compromise of looks, performance and budget the Kef KHT 2005.2 Eggs are a good solution to me.
My concern is the placement of the front three speakers. They will be accompanying a wall mounted 42" Plasma.
The most obvious location for the sats is the room corners, just under the ceiling. My issue is that the most obvious place for the centre is on the unit under the plasma. This means that sats will be about 1.7M higher than the centre which is far from ideal.
However, my inital thoughts are that small speakers look a bit naff on stands. I'm also not sure about mounting such small speakers halfway down the wall or by the side of the plasma - just think it would look a little odd.
I was wondering if anyone here has pictures showing possible ideals for installation.
Cheers,
Nigel
Cheers,
Nigel
