Any physical difference between AM2 and AM2+
Discussion in 'Computer Components' started by Gordon B, Feb 11, 2009.
  1. Gordon B
    Gordon B
    Dec 29, 2006
    6,082
    +1,053
    Hi all,
    I looking a a Zalman Water Reservoir1, but it seems to only have a block that supports AM2.
    So, and this may be a daft question but go with it, is there any physical difference between 2 and 2+. Basically would the cpu cooler that supports AM2 fit an AM2+ mobo.
    Thanks for your help.
    SD
  2. codename8778
    codename8778
    Apr 28, 2009
    33
    yea theres no physical difference, the fan will work
