Any Photoshop CS5 experts here ? Driving me mad
Discussion in 'General Chat' started by maxwell, Jul 31, 2012.
  1. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    Got a problem with transparency and browser compatability
    If I create a new image with transparent background, upto 5 layers and save it for web and devices, it shows as transparent on my desktop but when I put it into a web browser it has a solid white background :mad:.
    I have tried making it as indexed colour at 8 bits and saving as png24, png8, I have done everything I can think of but am obviously missing something as I have successfully achieved the correct result in the past.
    Any ideas ?
  2. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
  3. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    Thanks but the image is already transparent just not when it is put in a browser, IE, Chrome or Opera
  4. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
    Oh, so on your exported image on the file system the image is transparent?
    are you able to attach the image to a post for us to see? If only to clarify your current predicament
  5. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    PNG isnt as well supported as GIF. do you really need a PNG? it is the best for alpha channels and the only one that can do a smooth edge (on say a curve). ive never had issues with PNGs for years.
  6. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    if you copy the file it can sometimes copy the background colour too. i think thats a bug. how are you seeing this? copying from the page or a direct link?
  7. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    attatched rar contains the original psd and a png
  8. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    liam - yes needs to be png and the image is created from scratch, maybe you are right about the copying, strange thing is I have not had this trouble before
  9. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    ok. i opened it and then saved as png24. embedded on a basic web page in a div with black background, and it worked fine, in chrome and IE9 on win7 64bit
    here is my resaved file.
  10. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,020
    The png you attached is already fine and transparent,
    I did this
    <body style="background:red">
    <img src="3openvix3release-image.png">
    </body>
    And it worked fine, you sure you're not just viewing it on a white background? if you open the image directly into a browser it will always give a white background
  11. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    why does it need transparency anyway? is it a floating image over other things or for a forum?
  12. Foebane72
    Foebane72
    Mar 19, 2006
    3,414
    Cardiff
    +279
    I had a similar issue when creating the transparent PNG for my website logo.
    In the end, I simply started from scratch, by selecting a transparent colour for the background in Paint Shop Pro 5, and then drawing the logo on top of it that way. But PSP 5 is so old I had to use "PNG Optimizer" from a later version to satisfactorily create the PNG logo for the website.
    Does Photoshop allow you to create a new image with a "transparent" colour?
  13. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    The PNG in your .rar has transparency in all my browsers.
  14. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    thanks guys, the website its going onto has a blue/grey background, I now suspect it is to do with the way the website handles images.
  15. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    i think you mean the overlapping colour over aliases pixels? if so its the matte colour in photoshop web export but that is gif and png8 (which is basically a gif anyway) in png24 you dont need it as you have the required alpha channels
  16. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    its for a forum
  17. liamt
    liamt
    Aug 18, 2009
    10,250
    +2,488
    you can try gif and use the matte colour the same as the predominant background. its how we used to do it before PNG24s were widely accepted.
  18. maxwell
    maxwell
    Apr 27, 2008
    3,070
    +3,280
    just an update, apparently it has to be uploaded to the site as an album, it then shows as a transparency when used in a thread, must be something to do with VB4.2 as the site was recently upgraded and i didnt have this problem before.
