Any opinions on this VERY cheap 27"??
Discussion in 'LCD & LED LCD TVs Forum' started by noel-pilot, Jul 31, 2005.
Tags:
  1. noel-pilot
    noel-pilot
    Dec 20, 2004
    Seems very very cheap so if peeps more knowledgeable than me could comment that be very appreciated. if u want one try quidco.com and save another 5%!!
    Product Description Videoseven LTV27C 27" LCD TV
    Response Time 16 ms
    Display Resolution 1280 x 720 WXGA
    Display area (mm) 597 x 336 mm
    Panel Size CMO Panel
    Aspect Ratio 16:9
    Pixel Pitch (HxV) 0.4665 mm
    Contrast Ratio typ 600:1
    Brightness typ 550 cd/m2
    Viewing Angle H/V 170°/170°
    Screen Size 27” (68,5 cm)
    Displayable Colours max. 16.7 Mio
    Tv System NTSC/PAL/SECAM
    Teletext 10 pages
    Program Memory 99
    http://www.misco.co.uk/productinformation/~102110~/VIDEO SEVEN 27 L
  2. gaz@manc
    gaz@manc
    I've been lookin at this too - just concerned about ghosting/smearing when using a games console through it. Any opnions yet?
  3. chrisbrought125
    chrisbrought125
    Apr 19, 2005
    64
    +5
    Mines on it's way this week, I'll be able to post something about when it arrives. There's another guy on here who has it and says the PQ is excellent through his freeview box but no word about it's use on games consoles. 16ms sounds like it should be good enough though.
    Chris
  4. myjess
    myjess
    I ordered mine on Sat afternoon. I got the order number but it will not display anything if I go and check it on the MISCO site!
    Hopefully everything will be ok!
    BTW, is this the same V7 27" that has problems with come of the screens boing nuts after a while? I have read that some people have had to return them!
  5. chrisbrought125
    chrisbrought125
    Apr 19, 2005
    64
    +5
    Yeh I have the same problem on the Misco site, I hope everything will be fine on Monday when they've manually processed it. I'm worried about a typo and an increase in price though! Where did you read that the screens go crazy :confused: ?
  6. myjess
    myjess
    Cannot remember. Google it. It may well have been on this site!
  7. caverncity
    caverncity
    May 12, 2005
    132
    Just received this very quick reply to my question with regards to the Video7
    The native resolution of the V7 LTV"7C is 1280x720. This is excactly the
    resolution of HDTV 720p.
    The V7 LTV27C accepts HDTV via its component YUV connector and supports the
    resolutions 720p and 1080i.
    For these both resolution it is real 1:1 pixel mapping.
    You can find more genrell information about this topic on:
    http://videosystems.com/display/video_match/
  8. caverncity
    caverncity
    May 12, 2005
    132
    and it looks like it was a misprice. I knew I should have bought one. :mad:
  9. nickmanc
    nickmanc
    Aug 1, 2005
    13
    yes, was a misprice. just had my order cancelled :mad:
    Amazon have them for £479.99, which still seems reasonable - unless anyone has any better suggestions around the the £500 mark?
  10. myjess
    myjess
    Just had my order cancelled also. Darn. I am annoyed. 423ukp + VAT is the real price. Oh I am so disappointed, not that I thought I would actually get it :)
  11. chrisbrought125
    chrisbrought125
    Apr 19, 2005
    64
    +5
    same, reopened my cancelled amazon order! Looks like it'll b here 2moro :D
  12. chrisbrought125
    chrisbrought125
    Apr 19, 2005
    64
    +5
    Hi again, Videoseven LTV27C TV arrived on Monday and I've been using it for a couple of days so heres a quick review:
    Overall very pleased with it, first impression out of the box was good, very tidy unit with buttons on the top and inputs in two seperate compartments on the back. I've been using it as a PC monitor via VGA in 1280x768 last couple of days and it handles everything very well. Originally tried using the S-video output on my graphics card but picture was very poor as expected. No dead pixels from what I can see.
    When playing Pro Evo 4 and Brian Lara PC games there is no blurring or smearing which was something I was worried about as the screen is cheaper than most :thumbsup:. Pretty sure there wouldn't be any ghosting problems running consoles on it. Films are perfectly represented, blacks are rich and colours very vibrant. Text is pin sharp using a Belkin VGA cable (Dixons £19.99). The WinMedia 720p HD clips look fantastic.
    I tried it with my old Daewoo freeview box through scart and the picture was good, unless viewed quite close up but I imagine its the same with all other LCDs out of their native resolution. An old LG DVD player was a similar story. Hopefully my new progressive scan DVD player using component input will not have this problem.
    Sound quality isn't great using the internal speakers, lacking a lot of bass but a cheap subwoofer through the input would sort that out. I'll be using my Rotel amp and monitor speakers so SQ wasn't something I required.
    So for £480, it's a bit of a steal unless you need a (more futureproof?) DVI input.
    Hope this helps :D
    Chris
  13. Manny Brown
    Manny Brown
    AVF Games Reviewer
    Dec 30, 2003
    716
    46
    Cheltenham
    +157
    Hello all,
    Can anyone out there that has this TV confirm if you have any problems playing a 60hz source through the scart of composite inputs? Mine doesnt seem to support it, but 50hz is fine. Seems odd for a tv of this resolution not to support it.
    Can someone confirm whether i have a dodgy tv or not? Cheers.
