any one know where to get a DVI to RGB/component plug adaptor
Discussion in 'Cables & Switches' started by Starkiller, May 23, 2005.
  1. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Hi again
    im looking to input a component signal to my themescene H56 from dvi port.
    I have a dvi to rca male lead, but it looks a little thin and would need a gender changer adaptor.
    I have a VGA to component adaptor plug, but i would prefer to use the DVI connector(as ive got a keene scartblaster in that slot, and it would save me swapping leads)
    any ideas where to get one
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    Starkiller
    Just to be clear - your looking to Input YUV to the DVI-I port not the VGA port on the H56 Projector?
    Best regards
    Joe
  3. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Hi Joe
    Yes, the PJ RGB analogue or componet-p from the DVI port
    idealy it would be a 3 rca female plug input block to a DVI
    ive tried google, maplins, RS & CPC
    seem to be stuck?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    Starkiller
    Struggling to find a 3RCA(F) to DVI-I adapter for you.
    Have you considered a JS Technology 2:1 YUV automated switcher - that way you can share the YUV Input on the Projector with Two YUV sources and retain decent cables.
    If you want extra flexibility a Zektor HDS4 4:1 switcher (again programmed for automatic switching) enables up to Four YUV sources into one Input.
    Both of these options leaves your Digital Input free for a Digital source.
    Best regards
    Joe
  5. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    I cant find one either.
    I hadnt considered a switch, but im pretty much spent up at the minute
    after getting a new amp, dvd, speakers & leads.
    I have got a yuv-rca-f to D-15 vga plug(with the pj accessorys)
    just hoped to find the same sort of thing for the DVI port, guess ill have to survive with that, unless something turns up. I am suprised no one sells them.
    I also found a DVI-VGA block with a ATI graphic card, but 2 blocks would probably need supporting
    my dvd player has hdmi(hdcp) but my PJ doesnt have HDCP on its dvi port, so I will have to wait for the digtal connection untill i can afford some "box" to sort it out and another long expensive lead.
    Thanks for looking :smashin:
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    Hello Starkiller
    The JS Technology 2:1 YUV Distribution Amp is £50.00 + postage :)
    Best regards
    Joe
