Any news on release date for the High Def TOPFIELD TF7700 in the UK?
Discussion in 'General TV Discussions Forum' started by markbigears, Dec 18, 2006.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
  2. good2talk
    good2talk
    Oct 28, 2006
    32
    11
    +3
  3. amadeus
    amadeus
    Mar 7, 2005
    43
    +3
    Hi good2talk
    I am new to satellite gear so I hope you don't mind me asking a few (may be very basic) questions.
    Is it possible to record from this receiver by outputting to a PC or PRV? I am particularly interested in recording BBC HD. If you are already doing this perhaps you could explain how it's done.
    What sort/size dish etc will I need (to access as much FTA HD material as possible)?
    Did you consider any other STBs and, if you don't mind my asking, who supplied your receiver?
    Apologies again for any obvious questions
    Amadeus
  4. good2talk
    good2talk
    Oct 28, 2006
    32
    11
    +3
    Hi Amadeus
    Yes, I have connected it via a DVD recorder and it records fine HD Channels. I am sure you can record into your PC with correct connection.
    Astra 1 one and Astra 2 are the ones I am getting HD channels from so you need a 80cm dish with monoblock LNB or 2 separate LNBs with DisEcq switch.
    I had Humax HDCI-2000 before I was not happy with the quality of SD channels (even though it was good with HD channels). I am fully satisfied with Topfield TF7700 it gives crisp clear images even the SD channels are improved. I bought it from Turbosat email address [email protected] if you wish to contact them.
    Set up was so easy I did not even open the instruction manual. The menu is very user friendly.
    Good Luck!
  5. rover
    rover
    Jun 2, 2003
    60
    9
    Norfolk
    +12
  6. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    Bought one today, along with a 250GB pather black 5800 from Turbosat. Just got to rig the things up! £499.98 the two.
  7. uppal
    uppal
    Jun 23, 2003
    30
    London
    Does this topfield decode 4.2.2 feeds?
  8. zAndy1
    zAndy1
    Nov 26, 2002
    22,927
    2
    5
    163
    +9,377
    What HD channels can you get with this then?
  9. stainway
    stainway
    Aug 3, 2005
    1,711
    The Hague,Netherlands
    +90
