albani
First of all, o got a couple of pics from an Iron Man bluray, 4k HDR. 2nd pic is taken from really close to the tv (58PUS8505). Using default HDR vivid with the soap opera effect set to pure cinema.
Second, I have a question for everyone in this thread: what are your wifi speeds?
I'm on a 500mbps connection, tv's connected to my 5ghz network and it tops at 200mbps.
My phone (a OnePlus 6T) reaches 400+mbps on the 5ghz network.
Are you guys experiencing similar speeds? I wanna know if 200mbs is the tv's top speed on 5ghz.
-ask you; "distance"??? TV-Modem/Router
if your TV far of your modem that means your current speed down!
especially,if you have connected by 5Ghz "distance" is really matter!
note;do not try with 2.5Ghz !!
or check by "Ethernet",what will you get speed??
-secondly,if necessary change your Modem's port(Channel)!! (for 5Ghz connection)
enter your modem>>> 5Ghz>>select Channel 36/40/44
but first try at lowest figure such as "36"!!
and than select "Band Width";80Mhz
Mode;Mixed(802.11a/n/ac)
do not change it other figures!
"Phone"; do not think about phone's speed etc., they are so different!
TV's Wifi "chipset"; we do not know is it best quality/performance or which type of
WiFi etc.,
if such as "low" config as you wont get max speed!
and keep in mind,"distance" is most important matter for 5Ghz connection
for example mine is 60cm
but if get it such as 200Mb,this speed enough for everything!
