Any news about PUS8505
albani
Without going all the way back through can anyone please confirm the peak nit brightness of this please.
350nit
even 400 or 600 ....
at least accepted the right of the standard min.1000>>>HDR/DV
or at least you to have 700/800nit panel!
well,for me 300/400nit OK because of I do not watch any HDR/DV
AFM1
2020 vs 2021 medels have very small difference at specification
And 2020 roundly considered a dud, despite the specs promised on paper. I have the 43pus8555 and it's okay as a 2nd TV but not as a main tv
marioteli
Good, what configuration do you have in the ambilight? Because she had it at the standar and now at stake it looks good, but when there's a scene and the screen stays black, there's always a reflection of light instead of being dark
I have it in brightness mode 7 and contrast 2
Johnny Rico
Is there a way to access "frequent settings" faster ? (one button...) ?
I'm trying to find a way with Button Mapper Android app, but did not find yet...
For now, I managed to map Teletext and List bottom buttons to app shortcuts, like Kodi...works great so far.
thx
Dancap
TPM191E _ 101.002.022.002 – Date: 2021/05/14
  • Improvements for Ambilight Hue
  • PVR improvements
  • Fix for no sound after standby
  • Fix for unexpected appear of OLED screen saver when use apps
  • Stability improvements
  • Other general improvements
albani
radicspeter13
Next update will be 2 month later, so now we have some time to test these huge improvements out. Keep calm and hope to get the google tv UI update too.
honkhonkhonkhonk
I just got a new TV. Does the 65PUS8545/12 support wireless projection from Windows 10? Can't find the TV when searching for wireless displays. Do I have to activate something? I thought this had Miracast.
Also, how do I link the TV to Siri / IFTTT? Also also, can buttons / menus be remapped in any way? Just AWFUL menus. And finally, is it normal for the menus to be sooo slow?
albani
after latest download of last F/W(....022.002)
kinda there is no any "picture quality" improvements
note;
"clipping effect" still remain(but its due to 8+FRC type VA panel)!!
"flickering effect"(pixels-background crush etc.,) still remain but its all about 8+FRC&panel type
but there is a little bit improvement for this act(less visible)
>>Tip for this;"Sharpness">> use low level! such as 1/2
White col;more whiteish! when selecting Pic.Type >> ISF-Day with Warm&Movie
My panel 50"/85xx
in fact always my sets and satisfying for this panel almost fine and never complaint much
because of I know what I bought even with this price range!
What I did after last F/W
-Factory reset
-Re-Install TV
Note;I'v cleared&uninstalled all my Android Apks.
actually I do not use TVs Smart&Android etc., facilities because of I'v Android TV-BOX
even I never watch YouTube or any other pre-loaded programmes and even not to use
Built-In Tuner(inbuilt SAT.Receiver)
Pic.Type;ISF-Day
BL cont;80(it depend on content!!! such as "Movies" 30/40 or 50/60! or Sport/Studio contents
Out-door scenes,Nature or similar contents;this time level goes to higher such as 85/90....
Bright;49(or between 47-50)
Sharpness;my normal level is 0 but depend on some contents it goes slight high 3/4/5
2P;126(127)114/78 0/0/0
important set.! "Colour Control"
Red; 1 / 3
Yellow; -1 / 3
Green; -2 / 2
Cyan; 1 / 4
Blue; 0 / 5
Magenta; 0 / 3
above 2P settings and Type of Pic;ISF-Day set plus use this Col.Control
without any noise/ghost on the picture!
Bye++
petecod
Is the updated firmware available on the philips.co.uk website for usb install? File download is showing as the April update.
As doing an update via the TV itself is painfully slow!
philvalou
update carried out directly from the option on my TV, no change concerning the image which was already without problems on my 65PUS8555
starchilduk
Am getting an issue with prime video. When watching a series the first episode I watch always plays fine., then when it goes to the next episode the aspect ratio changes and the only way to get the correct aspect ratio is to quit the app and resume. When going back the menu that displays fine. Has anyone else have this issue? It’s only been recently that I have noticed this issue. Not updated to the latest firmware yet but feel it’s amazon rather than Phillips.
albani
Last F/W update date is>>(creation date) April/29 but you just ignore this date!
this date unnecessary for you as well
note;Server update link date is>>May/17/2021 ignore this date too!
keep in mind your latest F/W is>>> TPM191E_R.101.002.022.002
Note;it depend on your Internet-speed,it means that sometimes downloading time
may longer!
Or sometimes the main Server of TPS too bussy or due to unknown such as speed
issue then may your downloading time even more late too!!
Or go to this site and find your proper F/W link and download very fast
use FAT/32 formatted Memory-stick and download it than insert Stick to
TVs USB2.0 port and follow the directions,this way very easy and secure too
Link;
radicspeter13
note;
My panel 50"/85xx
-Factory reset
-Re-Install TV
Pic.Type;ISF-Day
Red; 1 / 3
Yellow; -1 / 3
Green; -2 / 2
Cyan; 1 / 4
Blue; 0 / 5
Magenta; 0 / 3
Bye++
Thank you!! These settings made my screen colour all areas the same.
Anyway, since the latest update i realized:
-Google play has been updated, not the app update menu is little bit more structured.
-Ambilight when tv is turning off has more delay to turn off automaticaly
-Chromecast tv screensaver does not forget it’s time waiting and sleeping periody.
markfawcett
My 65PUS8204 got damaged so a 65PUS8505 is replacing it tomorrow.
I’ll be interested to see if it’s as good because for the most part I was happy with the 8204.
Latest News
AVForums Movies Podcast: 1st December 2021
  • By Phil Hinton
  • Published
Rumour: Samsung even closer to OLED TVs in 2022?
  • By Andy Bassett
  • Published
Audio-Technica launches ATH-SQ1TW true wireless earphones
  • By Andy Bassett
  • Published
What's new on UK streaming services for December 2021
  • By Andy Bassett
  • Published
Best Projectors of 2021 - Editor's Choice Awards
  • By Steve Withers
  • Published
