Any motorised experts out there?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rigman, Jun 14, 2004.
  1. rigman
    rigman
    Dec 14, 2000
    2,937
    83
    East Yorkshire
    +98
    I have a Echostar AD300IP and a 1.3metre SCT Highway gregorian dish. For a number of months I have had a positioning problem which has been getting worse. The feedback pulses start acting strange and speed up or stop altogether causing the dish to lose position. I have set up my dish numerous times and then it happens again.
    I have looked at the motor arrangement on this dish and found it to be a simple electric motor and a few cogs. One of the cogs has a hole cut out od it and a reed sensor either side. As it spins it obviously sends pulses though the electonics and on to the receiver.
    Could the sensor be the problem? I would have thought it would either work or would not work and no in between? The problem can be there one minute and not the next.
    Could the reciever be the problem? I do not have a spare receiver I could try and I do not want to buy another and find the original receiver was okay and the problem was the sensor all along. It is not the wiring as I removed the motor altogeter and connected it at the receiver with a short lead and I got the same problem.
    Is there some checks I could do with a multimeter at the receiver end when the dish is moving to see if I am getting the pulses. What exactly do I look for.. I have checked the 5 volt line with is okay
    Thanks for any help
    Darren
    p.s If any one in Aberdeenshire has a spare receiver I could borrow for a couple of hours I would be extremely gratefull. :hiya:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,278
    Manchester
    +761
    Although it could be the sensor, many early Echostars had a faulty memory chip problem.
    I am wondering if that is the cause ; I can't remember what the symptoms of said problem were.
    (A Google search may find it).
    Chris Muriel, Manchester
  3. rigman
    rigman
    Dec 14, 2000
    2,937
    83
    East Yorkshire
    +98
    The sensor is just a magnet and it is mounted on a board with a couple of transistors and 3 resistors. If something had blown would it just stop working altogether?
    I wish I had kept my old analogue Pace 500IP now as a second test.
