Any media problems on Panansonics or sync problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by sparkydoo, Sep 18, 2003.
  1. sparkydoo
    sparkydoo
    On the panasonics models is there any problem using certain types of dvd-r.
    So the new 4 speed media is that ok to use in the e50 e60 or hs2?
    Also are there any known sync issues going from ram to dvdr etc/
    thanks
    sparkydoo
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    You need to try different media as some is more reliable than others and it seems to vary depending on the machine and the batch of media. I often get a fail to write error, but if I retry the media it usually works 2nd or 3rd try. This would be disastrous though if timer recording, which is why I only ever write to -r from the hdd. If it fails I can try again.
    There is a known sync issue if you watch a program whilst it is recording live. Simple solution is to watch in time slip mode even just a few seconds behind and the sound is back in sync.
    I have never had a sync issue in any recordings, uinless it was broadcast out of sync which is not that uncommon.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    Only if you go down an advanced PC editting route whereby you demux the file to run processing on it (e.g. logo removal). This would be audio displacement and occurs if demuxing from DVD-RAM or DVD-RW VR Mode - if your trying to do this on the DVD-Video structure (DVD-R, DVD+RW/+R or DVD-RW Video Mode) then you'll get audio displacement and stretching. Most people opt for the simple route of importing the VRO file into an authoring programme.
  4. malcom
    malcom
    Aug 25, 2001
    526
    +4
    I asked the same question directly to panasonic and their reply was that it is ok to use higher speed media as they will only write at 1x and no harm can come by using higher speed media on the Panny machines. I enquired in relation to the E20 and E30 so i assume the H2 range and E50/60 would be ok too........
  5. sparkydoo
    sparkydoo
    thanks for your replies so which one do i go for? The E50 as it is cheap and get a better one when improved models are out or HS2 now?
    Hmmmm
  6. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Seeing as you can get a multiregion hs2 for £545, you aren't saving much going for an E50, and you are giving up so many features.
    Once you have had a hs2 you wonder how you managed without the hard drive. I often have up to 12 hours of progs waiting to view and can still go ahead with a recording whilst viewing a pre-recorded one. How on earth can you do that on a -ram disc with only 2 hours available at reasonable quality.
    The replacement machine is no better in quality of recording, you just get a few more features and an 80gig hdd. THe only reason the hs2 is so cheap now is the availability of the new machine for about £800, and they need to shift the remaining unsold ones.
  7. drphibes
    drphibes
    Oct 23, 2002
    1,116
    48
    +33
    The e50 can be bought for around £245 so that means a margin of approx £300 between the two players you describe.
    I fully appreciate your opinions on the hs2 and the thought of having a hard drive does sound excellent but the e50 is a excellent machine for a lot less cash and might be the only option for many people on a budget.
    Drphibes
  8. sdh500
    sdh500
    But you can do pretty much the same thing with a Pace Twin Digibox. If I didn't have one, I might have gone for the HS2, but instead I put a bigger hard disk into the Digibox (60gb) and settled for the E50. If any recording turns out to be worth keeping, I just transfer it to dvd-r. Simple. :)
