Any MAME/JAMMA experts here?!
Discussion in 'PC Gaming & Rigs' started by Waka, Jun 2, 2004.
  1. Waka
    Waka
    Feb 17, 2004
    52
    I wasn't sure whether to post this in the retogaming forum, but I saw that gthom3 posted here today and he mentions his Jamma cab in his sig :)
    I've got an old pc (500Mhz Athlon 256MB ram) with an Ulitmarc ArcadeVGA card and a J-PAC into an old Streetfighter cabinet.
    I can get the display working fine on the computer monitor and the arcade monitor works fine with the Streetfighter board in there - but when I put the pc in the arcade cabinet, the display is unreadable. I've tried changing the dip-switches on the J-PAC and I'm sure the graphics card drivers are ok, but I just get a 'smeary' display that's unreadable.
    I've also got an old rage 128 pro which is supposed to be up to the job, but the display is the same.
    Have I done something really obviously stupid?
    Help and thanks!
    W.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,827
    +1,119
    http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=ultimarc
    Here are the official forums, don't know if you have tried there?
    Sounds like it is a resolution problem, which is strange with the ArcadeVGA card as it is only supposed to display in 15Khz at proper res. Sounds like it could be a connection problem, have you tried another lead?
    I doubt it is drivers as you should see the PC boot-up screen, this does not relie on windows drivers and so it would indicate a hardware fault (either cable or card).
