Any luck dubbing chapters onto DVD-R?
Discussion in 'Blu-ray & DVD Players & Recorders' started by schwig88, Jun 8, 2005.
  1. schwig88
    schwig88
    Howdy! I just got a Panasonic EH50 recently and have since been merrily backing up & dubbing DVDs.
    With particularly long programs I'm inserting chapters so that I can fast foward the DVD in the future.
    It seems you can only insert chapters onto HDD programs. Ok fine, but when I dubb the HDD chapter'd program onto DVD-R (or RAM) the chapters all disappear. And I've tried all the various speeds.
    Has anyone had the same experience or any luck trying it otherwise?
    Cheers!
  2. ben223
    ben223
    Your own chapters will only be retained if you use HS dubbing, otherwise they will be inserted automatically every five mins.
  3. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I just got mine the other day and have had this same problem. Chapters also haven't been inserted every 5 minutes.
  4. philipb
    philipb
    Mar 6, 2002
    2,058
    63
    Swindon
    +153
    Sorry if this too obvious, but have you finalised the discs? The chapters are inserted, or should be, at that stage.
  5. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    Cheers Philipb, it actually was that easy!
    Funny thing though, I checked the chapters on the eh50 before finalizing and got grumpy because the chapters I had set up on the HDD had not been transferred. Then I checked the disc on a standalone player after finalizing but did not check the chapters at that point as I assumed it hadn't worked.
    However, it hasn't worked as expected. The chapters I put into the recording on the HDD seem to have been ignored and I just have the standard 5 minute interval chapter breaks. Do I have to set the chapters on the DVD itself before finalizing?
    Also, I have found the option to record for high speed dubbing and have turned this on. Is there any good reason not to leave this on? I understand about the widescreen auto switching flags and the bilingual audio but do these matter? Am I right in saying that the image recorded will still be anamorphic but I just have to adjust the aspect ration on the TV myself?
  6. bradavon78
    bradavon78
    May 31, 2004
    3,202
    South West, England
    +133
    Yes if the source is anamorphic (of course).
  7. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    Cheers bradavon.
    Is there any way of high speed dubbing a file that hasn't been recorded with record for high speed dubbing turned on? Am I doomed to having to put live 8 onto DVD in real time? :(
