Any LCDs with 2xHDMI, 3xSCART (2xRGB) & Component?
Discussion in 'LCD & LED LCD TVs Forum' started by rnem170, Aug 2, 2006.
Tags:
  1. rnem170
    rnem170
    Oct 17, 2005
    262
    +20
    :lease:
    Does anyone know whether there is anything which matches the connectivity (or comes close to) the old WLT58 series Tosh?
    I currently don't have any HDMI devices, but do have the need for three SCARTs and Component at this time. All the latest kit seems to have gone away from 3 SCARTs which is a real pain.
    Cheers, Rob
  2. Will4long
    Will4long
    Feb 1, 2006
    55
    The Toshiba 32WLT66 comes close with 2xHDMI, 2xScarts, 1xRGB and component according to Comets spec. So misses out on 1xRGB.
  3. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    Most will only have 2x SCART these days because it's an outdated connector than can only be used with interlaced video, whereas replacing it with a component jack allows for progressive scan.
    While the BRAVIAs only have 2xSCART, both of them are RGB. (means no s-video though, you have to use the side connection for that) I believe the V2500s later in the year will have 2x RGB, 2x HDMI and 1x Component.
    You can always get switch boxes though - Joytech make fantastic RGB ones for about £70, and you can get 5>1 HDMI for about £150.
  4. colin45
    colin45
    Jul 13, 2006
    64
    I think that the Sony X series have 3 scarts 2HDMI and component
  5. ndavies4
    ndavies4
    Feb 3, 2005
    84
    Kingston, Surrey
    The older model Tosh '58' series had what you're after
