Any Latest comments on these 2 TV sets
Discussion in 'Televisions' started by Rookies, Jan 4, 2003.
  1. Rookies
    Rookies
    Jan 4, 2003
    4,894
    103
    +344
    I am thinking of buying one of these tv set. But I have heard some good comments aswell as bad. Just wonder if anything had improved since which I doubt.
    The tv are
    Sony KV32FQ80
    Panasonic TX32PH40
    Cheers in advance
  2. paulsheerin
    paulsheerin
    I did think of getting the PH40 but it was a little over my budget.
    From what I saw in the shops it seemed very good & I reckon its one of the most aesthetically pleasing sets around. would have looked the business in my living room.
    Whats the best price you've seen for it btw?
  3. Rookies
    Rookies
    Jan 4, 2003
    4,894
    103
    +344
    Paul yes I agree the panny looks a nice set it looks the dogs. I pretty like it very much and I have had a look at one working and it seem very good. I even went into the menu of this tv and there was a flicker option i turned it off and the screen flickers a bit like we all see and when i turn it back on the screen is sharp and nice picture and no flicker.
    The price off my head I think i seen this for is around the 1100 mark but cant remeber for sure. What the cheapist you seen this for paul?
    Here are a few things people told me in shops but i dont know if it true which put me off the panny just incase I needed the feature
    Is that the sony FQ80 let me switch between 50hz to 100hz just incase i need to go to 50hz for sports like football as I am into sports.
    And the panny does not have this feature but i felt that turning the flicker free option off it would do the trick but aint sure
    Any ideas folks
  4. paulsheerin
    paulsheerin
    The best price I saw was £1150 on the net.
    I read many posts about problems watching footy @ 100hz and it did put me off a bit so I too was looking for a set that could switch between 50/100hz.
    In the end I could find one that I liked within budget so went for the FX66.
    I have been watching footy all weekend from the FA Cup BBC to German & Spanish Footy on Digital Satellite and the picture is fine. No smudges smears or comet trails as I could see anyway.
  5. Rookies
    Rookies
    Jan 4, 2003
    4,894
    103
    +344
    What setting did you use then? Did you leave it as 100hz or did you set it at 50hz for the sports?
