Any known problems with sky link and LCD tv?
Discussion in 'Sky Digital TV Forum' started by Rookies, Oct 25, 2005.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    As subject I just cant seem to get the sky link to work with my LCD. When I have my skylink connected to the cable without having it pluged into the tv I can change sky channels. But when I do plug it into my LCD tv I cant change sky channel I have a feeling the sky eye does not like my lcd tv is this a known issue?
  2. morganog
    morganog
    There is an issue with some tv's----If your "SkyLink" doesn't work while connected to your TV set but does work when you disconnect it from your TV and just hold the connector close to the aerial socket, then a Decoupler should solve your problem!!!!
    check this out!!!
    http://www.satcure.co.uk/tech/tvlink2.htm
