any installation fitters in the nottingham area
Discussion in 'Home Cinema Buying & Building' started by karlosvandango, Aug 4, 2005.
  1. karlosvandango
    karlosvandango
    im looking for a installation fitter in the nottingham area to mount a lcd tv to a plasterboard wall & conceal the wires.
    cheers karl
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    Try NTN Home, based in Derby.
    A newish company, but plenty of experience.
    Contact can be found via www.konnect2.net
  3. karlosvandango
    karlosvandango
    thank you for your rely,i will give them a call
    cheers.
  4. JohnM8
    JohnM8
    Hi, I'm looking for the same, only to mount on breeze.
    Was woundering what a typical charge might be for this sort of installation.
    I may attempt it myself, having chased out walls before, but I wouldn't look forward to the prospect.
    Would I need to create two channels to separate power cable from the rest?
    And are the power leads universal to fit different models, I wouldn't want to be re-chasing should i decide to change the TV a few years down the line.
    Any help greatly appreciated
    John.
