any info on samsung 709
Discussion in 'Blu-ray & DVD Players & Recorders' started by pete o'flanagan, Oct 4, 2001.
  1. pete o'flanagan
    pete o'flanagan
    hi all,
    I'm considering buying one of these units as a backup,any info on this model will be useful...i:e remote hack for multiregion/macro off picture/sound quality..etc.etc.
    thanx Q.
  2. naim
    naim
    Sep 28, 2001
    140
    up north
    check your email
  3. Martin Clarkson
    Martin Clarkson
    I would very much suggest you get yourself onto www.709online.com, this is THE biggest resource on the matter. I have had one of these babys for a 18 months and have found it to be a right little gem, see how ya go !
  4. ISCM
    ISCM
    Do not buy a 709. I had one and got rid of it , because the sound was so bad. You can get a multi region Marantz of Pioneer for the same money and both the picture and sound will be better. i would go for the Marantz because the machine is quiet, it has two SCARTs and needs no modification to play region 1 including RCE discs. :eek:
  5. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    Can you tell me more about the Marantz?
    I have a 709 right now and am on the verge of buying a Pioneer 545.
    But I want 2xSCART and SVCD support, but I would also like decent FF/REW speeds, which the Pioneer doesn't have.
    Is there a 'hack' for the Marantz, or does it have to be mod'd.
    Any info would be appreciated
    Jon
  6. ISCM
    ISCM
    There is a hack for the Marantz, but a good shop will provide it ready modified. It will also play RCE.
