gobstopper
Established Member
I have a Panny DMR-EZ25 recorder which has served as a faithful companion to my 4-year-old DMR-EH60D for just over two years, but of late it seems to have developed a rather strange problem with it's sound. However, the problem does not appear to be consistent with any one source or indeed with a particular output which has left me scratching my head...
I have tested the recorder with it connected separately via HDMI and Scart. What's making things more confusing is the fact that in certain cases it doesn't matter if the unit is connected using scart or HDMI and in other cases it does.
When connected via AV1 (scart) to TV the sound is horribly distorted if the source is:-
Things get more confusing if I swap the scart cable from AV1 to AV2 on the recorder. This was something which I did simply as a test. As far as I can work out, this shouldn't work at all as everything in the instructions suggested that AV2 in an input, rather than an output. But when connected in this fashion not only is there a perfectly clear picture on the TV, the problem with DVDs (as described above) goes away and they play without any sound bleed or distortion of any kind. However, if the source is one of the analogue channels the sound is still up the swanny.
Sound is OK when the recorder is connected to the TV using the HDMI connection and the source is a DVD. But if I connect a source to AV2 on the recorder, select channel AV2 and try to watch it over the HDMI connection the sound is distorted.
The only thing that I find works consistently is when the unit is tuned into a freeview TV channel. Regardless of the chosen connection method between the recorder and the TV, freeview channels do not exhibit any sound distortion at all.
I'd love to know what's going and if it's viable to try and get it fixed?
I chose the Panasonic recorders largely for DVD-RAM usage, but also because they all sported digital and analogue tuners - therefore allowing me to record something on this recorder over RF from my Sky box if my primary recorder was busy doing something else at the time. Of course Panasonic have long-since dropped the analoge tuner from their range, so if it didn't turn out to be worth the repair I'm at a loss what to replace it with. It is also (as is my DMR-EH60D downstairs) a multi-region unit as I have a number of R1 discs.
Any thoughts or ideas would be gratefully received.
- The analogue tuner (which I use a lot in order to record programmes from the 2nd RF output from my sky box - the recorder is actually located in one of the bedrooms).
- A source connected to AV2 on the recorder
- A DVD - not only is the sound of the source distorted in this case but it there is also evidence of the sound from whichever TV channel (analogue or freeview) selected bleeding over the top - also distorted.
