I'm putting pc's in my two childrens bedrooms. But I also want them to be able to access their pcs from the kitchen.
Bedroom setup will be normal dvi to monitor wireless keyboard and mouse to usb
What I'm thinking is running a second dvi from the back of the pc plus a usb connection to a switch system in the kitchen, the usb and dvi from each room go into the input options on the switch and the output from the switch goes to a monitor (dvi) and a usb hub with another wireless keyboard and mouse
If I tell the pc to treat the two monitors as mirrors then you should get each childs desktop at the flick of a switch.
DVI splitters are available although I'm not sure about the usb bit, but I can handle a soldering iron so I could probably do that.
But the big question is would this work or does anyone know a better solution?
And if the answer is yes can I then really complicate the system by having an equivalent setup in the office, so they could access their pc from their bedroom, the kitchen or the office.
Obviously with a system as complex as that there is the option for some fool child to try and run his/her pc from all three locations, but I'll just ban the computer for a week if they try that so we don't need to paln for that scenario
Any ideas?
Any ideas?
