Any ideas? - KAC-8152D amp & JBL sub
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by bigtaff, Feb 10, 2009.
  1. bigtaff
    bigtaff
    Nov 18, 2006
    70
    I have just installed a KAC-8152D amp and JBL sub in my car, wired it up etc but amp will not switch on. I have checked for power - check, Checked the Earth - check but not sure how much output I should expect from the remote wire to do the switching on? I would think it would only be a few volts (at a guess) but Im getting no reading at all from my tester. Does anyone know what the stereo should put out power/voltage wise to tell the amp to power up?
    Cheers, Taff :thumbsup:
  2. IANOLIVER
    IANOLIVER
    Sep 28, 2008
    173
    +23
    Remote output should be 12 volts.
  3. bigtaff
    bigtaff
    Nov 18, 2006
    70
    Oh dear - so I have a duff head unit then possibly!?!?!?! Bugger. Everything else works on the radio but no output on the remote lead. Its a Kenwood headunit but came with the car so maybe I will have to bite the bullet and buy a new one now I have invested in all this gear!!! :mad:
  4. IANOLIVER
    IANOLIVER
    Sep 28, 2008
    173
    +23
    Check you are using the correct lead, the remote output on a Kenwood is blue or blue/white.
  5. bigtaff
    bigtaff
    Nov 18, 2006
    70
    I am, it was left in the car by previous owner of car who had an ICE install too - Maybe a fracture in the wire or something?
  6. Andy4k6
    Andy4k6
    Jan 1, 2009
    207
    +16
    Was the loose remote wire safely looked after? I.e has it been shorted to earth at any time?
    You could cheat and used the switched live from the ISO plug, Not exactly ideal and could cause some minor proplems like on/off pop but worth a try if you don't want to buy a new hu.
    Andy
  7. bigtaff
    bigtaff
    Nov 18, 2006
    70
    It was a fracture in the remote wire after all - sorted!
