Question Any ideas how to get 5.1 working on PS4 using ARC?
Discussion in 'AV Receivers & Amplifiers' started by Stluke1877, Apr 1, 2016.
  1. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Dear All,
    I have a PS4, Panasonic 4K CX680 TV and SONY BDV N5200.
    I do have other workarounds but if I connect PS4 direct to TV and attempt to use ARC function it will not output 5.1 under any circumstances no matter what settings I change on the receiver or on the PS4.
    I can happily and easily get 5.1 DD through ARC on my Sky HD box so I know it's possible.
    Any tips or magic solutions would be greatly appreciated.
    Many thanks,
  2. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    TVs do not generally passthrough multichannel audio if accessed via external devices connected to their HDMI inputs. Besides which, most audio content and especially games audio output via a Playstation will be multichannel PCM which cannot be conveyed via ARC.
  3. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Thank you very much for the reply! That's really strange as I have my sky HD box connected directly to the TV in HDMI and I get 5.1 DD through my receiver using ARC. Didn't understand why PS4 will not do the same
  4. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    What audio formats are you attempting to passthrough? AS I said, ARC can't convey multichannel PCM, but also cannot convey HD formats such as Dolby TrueHD or DTS-HD Master Audio. ARC is limited to stereo pCM or SD 5.1 formats such as Dolby Digital or DTS.
  5. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Just simply DD. No matter what I try it steadfastly refuses to output anything other than PCM 2.0. Sky HD no problem whatsoever but PS4 seems to be a law unto itself. Even more galling since the blu Ray receiver is Sony
  6. diver5
    diver5
    Dec 14, 2015
    155
    Manchester
    +19
    The settings on my PS4 are PCM, Dolbly Digital or DTS. When you choose one your just choosing the order preference they are used in rather than explicitly using just one.
    My PS4 is connected through my amp but whatever setting I set the PS4 to I always get 7.1 as a minimum into the amp (playing games or the dash board). As ARC is limited to 5.1 I wonder if this could be the reason?
  7. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    It could be. I have tried every combination of settings on the amp and on the PS4 switching HDCP off HDMI control off etc. The PS4 either has an ARC issue or I'm being a dimwit. Either option is possible
  8. diver5
    diver5
    Dec 14, 2015
    155
    Manchester
    +19
    Do you have a standard 5.1 DVD movie you could try playing (on the PS4) to see if you get 5.1 through the ARC with just a 5.1 source?
  9. JonJ
    JonJ
    Nov 11, 2006
    395
    46
    Up North
    +131
    I have a PS4 and Sony TV with a Yamaha soundbar connected via ARC. I confirm that the TV (as per other posts) does not allow 5.1/DTS through ARC. I have the PS4 connected direct to the soundbar.
  10. Oswald
    Oswald
    Suspended
    Oct 10, 2013
    2,332
    117
    +1,299
  11. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Good idea I will try that later at home see if it does it. My gut feeling is its a PS4 specific issue with ARC but then my knowledge is so limited I wanted the opinions of people that know far more than me! I wonder if there's anyone out there that can confirm they have got 5.1 working in this setup on PS4 through a receiver/amp?
  12. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Oswald, thank you I will check that thread out and see if there's a solution...
  13. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Seems the PS4 is riddled with HDMI audio issues...
  14. mbmapit
    mbmapit
    Feb 15, 2005
    1,847
    Stansted
    +403
    Is it going in to HDMI port 2? This is the only port that supports ARC on your TV.
  15. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Receiver goes into HDMI 2 (ARC) sky in HDMI 1 works perfect with ARC, IF I PUT PS4 in HDMI 1 absolutely no chance
  16. andy1249
    andy1249
    May 7, 2006
    8,459
    +2,549
    ARC is a set of optional CEC commands within the HDMI interface.
    The problem is that these are " optional" and not standardised.
    Some devices use the standard CEC commands , but any manufacturer that has their own CEC command set uses those instead.
    Sony have their own, called " bravianet" , and these are only guaranteed to work with other Sony equipment of the same generation.
    Because of this ARC / CEC is generally an unreliable mess, and where at all possible you should forget about it and just connect directly to the receiver and or use a universal remote like a harmony.
    The fact that Sky works and your PS4 does not simply means that sky are using a command set that is compatible with the rest of your equipment but the Sony does not.
    Its not a fault as such, Sony would call it a "feature" and suggest you get more Sony gear.
    Thats the way it is with ARC / CEC at the moment and its not likely to change, you will get similar issues with other manufacturers.
    Samsung = anynet
    Panasonic = Vieralink and so on ....
  17. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    Andy thank you. I guess it's one of those things although maybe I was over optimistic that 2 of the 3 components involved (PS4 and surround sound) are both SONY! You are right of course, I can (and do) connect directly to the receiver I was just experimenting with picture quality on both SKY and PS4 by connecting directly to a 4K TV set and not having the blu Ray receiver add an extra level of processing if that makes sense. Just frustrating SKY can do 5.1 DD through ARC with a Sony blu Ray system and a Sony PS4 can't
  18. andy1249
    andy1249
    May 7, 2006
    8,459
    +2,549
    Sony blu ray to sony PS4 should be fine, stick the panasonic in between and it becomes a compatibility issue between Bravialink and Vieralink....there is pretty much nothing you can do about that unfortunately.
  19. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    That makes sense although my OCD part of my brain wonders why Sky to Panasonic to Sony works and Sony to Panasonic to Sony doesn't! C'est la vie I suppose although I bet I don't stop trying to "fix" it!
    Really appreciate the info
  20. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    The Playstation uses standard HDMI CEC and no mention of Bravia is made within its HDMI settings. ARC is a subset feature of HDMI CEC and has nothing to do with various interpretations of HDMI Control being employed by the different TV manufacturers. If there is an issue with ARC associated with a device then it is due to the manufacturer not correctly implementing ARC. ARC is not open to interpretation and is a set standard. THe source is not the device dealing with the ARC signal. You can turn HDMI control completely off onboard the Playsation and you should still be able to convey audio from the TV to the AV receiver. The Playstation is playing no part in the conveyance of audio via ARC and is simply the source of the audio. Likewise, the SKY box has nothing to do with ARC and is simply the source of the audio being conveyed. Iys HDMI CEC capabilities play no part in this and you can turn HDMI Control off onboard the STB and still convey audio from the TV to an AV receiver via ARC.
    I'd suggest the issue nothing at all to do with incompatibility and more a matter of how the PLaystation outputs various types of audio. For a start, games are output as multichannel PCM as opposed to Dolby Digital or DTS because the console needs to decode the audio itself in order for it to then be able to mix in audio it creates. As I said before, ARC can only convey 2 channels of PCM data and is limited to the same audio as associated with S/PDIF optical. In fact ARC uses the same S/PDIF protocol as optical or digital coax. Also note that Disc based media such as DVDs or Blu-rays don't automatically bitstream audio if the console is set to bitstream via the main settings. The console will output multichannel PCM from such sources unless you first insert a disc and play it before then pressing the "Options" button on the PS4 controller, select settings and set Audio Format to "BITSTREAM (DIRECT)". The console retains that setting for all future discs of this type. Again, if this wasn't already done then the console would have been outputting multichannel PCM and not Dolby Digital or DTS and ARC cannot convey more than 2 channels of PCM data.
    I'm also not sure how you are managing to passthrough Dolby Digital 5.1 from your SKY box? TVs other than Sony sets cannot passthrough multichannel audio accessed from external HDMI devices.
    All in all, the solution is to make a direct connection from the source to the AV receiver and this is what is usually suggested regarding any HDMI source. It is recommended not to connect sources directly to a TV via HDMI and passthrough audio to the receiver for the very reasons you are having issues with.
  21. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    I have no idea to be honest but I am DEFINITELY passing through 5.1DD from Sky to Panasonic TV. Sky is directly connected to TV via HDMI 1 and has no connection with blu Ray receiver whatsoever. I then have receiver connected to TV via HDMI 2 ARC. I set receiver/blu Ray to TV input and it most definitely outputs 5.1 DD from sky (dependant on channel eg Sky movies HD)
  22. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    Read my modified post above, especially this section:
  23. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    It all started off a with an experiment in picture quality to be honest. I agree going through receiver is the optimum route for sky and PS4 which I can do easily. Perhaps it's me, my brain doesn't like a problem I can't understand:).
  24. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    So if understand correctly there's absolutely no point even trying the ARC route for games as they output PCM so it will always be stereo?
  25. andy1249
    andy1249
    May 7, 2006
    8,459
    +2,549
    Dante, for ARC to function, HDMI CEC must be on on the ARC device and on the receiver, in that respect it is a subset of CEC and cannot work without it.
    Different proprietary CEC command sets ( note ...NOT the optional standard commands) do prevent HDMI CEC from working between different devices and as a result are known to cause ARC to fail.
    Its a regular occurance.
    Obviously, by connecting directly ARC is not needed and bypasses the whole issue, so that is the best way to go if possible.
  26. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    That makes sense as well because ARC does not even function if I disable it on blu Ray. I know and I will connect directly but when you get something in your head...:) Would not have even thought twice but when I had sky working I thought"why not try it with PS4 as well"?
  27. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    Correct, although you can force the console to bitstream the audio, but this would result in the absence of audio created by the console for use in the game.
  28. dante01
    dante01
    Mar 5, 2009
    44,870
    +10,545
    The console and the SKY STB are not ARC devices. Only the TV and the receiver are ARC enabled.
  29. Stluke1877
    Stluke1877
    Feb 24, 2016
    42
    Cannock
    +4
    All of you thank you so much for your help and indeed knowledge. Seems I cannot use ARC and 5.1 certainly for gaming on PS4. Slightly off topic but connected to what I was trying to do in the first place- my blu Ray rceiver BDV-N5200, if I connect my PS4 or any other component to it with HDMI, how do I know if it simply passes through the video signal or if it is attempting some sort of processing? Read the manual cover to cover but as with most Sony literature it's not the clearest!!
  30. PSM1
    PSM1
    Dec 20, 2008
    26,266
    +5,423
    Could the 'issue' be that the Sky box is dumb in terms of HDMI control/CEC? As far as I remember Sky has no HDMI control built into it while the PS4 does. I may be wrong but would this mean that the Sky box would not 'see' the TV as a stereo source but the PS4 would. Hence the PS4 would modify its sound output to match what it thinks is receiving it i.e. the TV while the Sky box would blindly just send the sound that has been set within the Sky box itself? This could be why 5.1 is forced through with the Sky box but not the PS4? All the above could be complete rubbish but may form an explanation.
