Any idea how much?
Discussion in 'TVs' started by docfeelgood, Sep 22, 2003.
  1. docfeelgood
    docfeelgood
    Sep 9, 2003
    237
    I'm selling my Panasonic TX36-PF10 (36" CRT) locally but have no idea what price to put it up for.
    Any ideas how much I can expect to get for it?
    I'm replacing it with a Toshiba WH36 RPTV.
    cheers
  2. nathan_silly
    nathan_silly
    Dr. Dog:- "Ten quid" :)
    Seriously, £1600 new, so I would say half of that. So that's £300. :p
  3. docfeelgood
    docfeelgood
    Sep 9, 2003
    237
    That's just silly ... Nathan ;-)
    Seriously tho... only 300 quid ?
    You seen one of these WH36's yet then matey? .... being the RPTV guru of the forum as you are.
    I'm searching out a demo at the mo.
    Kind of changing everything video-wise at the moment.... going for (at the moment!):
    Bedroom - either a Panasonic PD30 or Tosh PF2 (32)
    Lounge - Tosh WH36 (42)
    Study - Panasonic PTAE300 projector (or maybe the AE200) and some sort of screen.
    with about a 3.5k budget...... about what a plasma would cost me ;-)
    any other/better suggestions for the money?
  4. nathan_silly
    nathan_silly
    My maths was off. :) I would say £800.
    Buying quite a bit of stuff there. Be careful with the bedroom TV - think quite a few of people are unhappy with Panny and Toshiba TV's. It seems normal TV Quality control has dropped to point where everything is faulty :( That's why I bought a RP- they have more advanced geometry adjustment (if you're willing to go into convergence service menu)
    Oh the 51" Toshiba RP is only slightly more than the 42"- can you get away with it?
  5. Demon
    Demon
    Dec 13, 2000
    956
    Cheltenham
    +57
    My Brothers 51WH36P arrives in the next hour... I'm on my way over with some DVD's etc to 'check' it out...
    Will post later..
  6. docfeelgood
    docfeelgood
    Sep 9, 2003
    237
    Nice one.
    Not sure if I can fit a 51" in (I'll measure when I get in from work).
    Won't the 42 have a better picture due to it's smaller screen with same amount of pixels etc ?
    I know this rule applies to CRT's .... not sure about RPTV's tho.
