Corbula
Established Member
So I'm currently using a 32 inch LG from 2008, there nothing majorly wrong with it apart from there's some times no picture until its warmed up a bit.
Anyway looking for alternatives I've been restricted to a 32 inch TV as the space it's going into is an absolute max width of 890mm. Everyone seems to be making 40/42 inch then I found a Hisense 39 inch H39A5600UK which would just (really just) fit. One thing I was put of by was they use there own smart software instead of say android or something.
I couldn't find any reviews of it anywhere though. Any ideas of how good it is? Or would I be better with another 32 inch TV, what would you recommend? I mainly use it for HD TV, films and Ps4 gaming.
Thanks all
Thanks all
