Any help greatly appreciated
Discussion in 'Home Cinema Buying & Building' started by neilbart10, Jul 15, 2015.
  1. neilbart10
    neilbart10
    Dec 24, 2013
    10
    Hi there
    I am just about to attempt my first home cinema set up and was looking for a wee bit of advice.
    I am looking at a 100 inch screen and the two that I have found in my budget are:
    Luxburg® 100" 221x125cm 16:9 Full HD 3D Premium Fixed Aluminium Frame Projector Screen - PVC Fabric (87" x 50")
    Elite Screens ER100WH1 SableFrame Series 100 "Screen for Projector White
    Are these much of a muchness or is one any better than the other?
    The other question I have is would it be better to mount the centre speaker on the wall under the screen or sit it on top of a unit under the screen?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    Speakers do not generally like being in or on a cabinet and will not sound their best it that situation.
    So either use a speaker stand for the centre or wall mount with a suitable speaker bracket.
  3. neilbart10
    neilbart10
    Dec 24, 2013
    10
    Great thanks for your reply.
