Any help for lost channels and ropy signal?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by calscot, Oct 17, 2003.
  1. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Does anyone know what the problem could be with me loosing a load of channels except BBC, Channel 5 and a few others which seem to be fine?
    (I have freeview and have registered with Pout to keep the itv channels)
    I get something like "No satellite signal received" for ITV, Channel 4, TCM etc.
    Even channels 998 and 999 are breaking up all the time.
    I did the signal test which gave the strength as about 50% and the quality as 0.
    Could it be my dish has been moved by the wind or something?
    All help gladly received.
    Cheers,
    Cal.
  2. Fernsehman
    Fernsehman
    I think you are totally confused. You can't get "Pout" from a Freeview box. You need a Sky Digibox. No wonder you've got problems!
  3. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Perhaps I should be more explicit - I have ***SKY!!!*** but with a freeview card which is registered with Pout for the sole and specific reason that it allows me to continue to watch ITV, C4 and Five.
  4. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    I've had a search through the digital spy forum and now have a few leads to try. It seems a better forum for this kind of stuff.
    Thanks for looking anyway,
    Cal.
