Any help - appreciated
Discussion in 'Projectors, Screens & Video Processors' started by Drogo, Jan 5, 2004.
  1. Drogo
    Drogo
    Dec 13, 2003
    289
    English Riviera
    Guys,
    After thinking about getting a plasma, I have opted for the Panasonic PTAE300EC
    [You can't link to pictures on others' sites without permission - bandwidth theft - Kramer]
    Question is: what screen to get for a small lounge, not expensive though, please advise
    Home Cinema LCD Projector
    960x540 resolution
    800 ANSI lumens brightness
    Contrast ratio 800:1
    Horizontal and Vertical keystone adjustment
    SD memory card compatible
    RGB SCART input for easy connection
    LCD Panel 0.7" (diagonal) 16:9 aspect ratio LCD Panel
    Pixels Approx 1,555,000
    Lens Manual Zoom1-1.2, F2.0-2.3
    Lamp 120W UHM
    Colour System PAL/PAL-M/PAL-N/SECAM/NTSC/M-NTSC
    Projection size 40" - 200" (16:9 aspect ratio)
    Screen Size 1016-5080mm diagnally, 16:9 aspect ratio
    Installation Front/Rear/Ceiling/Desk
    Audio 2W(mono)
    Video In S-Video (mini DIN 4 pin), Video(RCA pin jack) Audio (RCA L&R x 1, 0.5 Vrms)
    PC In RGB-D-SUB HD 15-pin femalex1
    Component In RCA pin jack x3, Audio-RCA pin jack x2 (L&R)
    SD Card Slot motion pictures: MPEG4 compliant
    Operating Temperature 0-40 Deg C
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    Hi Drogo,
    Could do with some rooms sizes ;)
    But a 5.5ft screen (Sony manual pull-up) from Nexnix £100. Not bad either. We bought one six months ago and its still going strong (Dads got it now) :clap:
    Jack
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Depends on how far the projector is gonna be from the screen.
    Once you know that you can go here and find out what size screen you will be able to have.
  4. Kramer
    Kramer
    Moved to screen forum.
