Any Hdd/Dvd Recorder finalise discs as NTSC?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jwright118, Jun 28, 2005.
  1. jwright118
    jwright118
    Mar 25, 2005
    26
    3
    Does anyone know if there's a dvd or hdd recorder that will finalise dvd-r's as ntsc from a Pal input signal (vhs tapes)? I Know some pioneer, and panasonic models will finalise discs recorded from an original pure ntsc or pal60 input signal.
    Only, as someone else in the forum was saying, if your looking to get into dvd-r trading, ntsc seems to be a lot more common globally.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,509
    7
    167
    Birmingham, UK
    +10,235
    It sounds like you are refrring to swapping copyright material, which is, of course illegal.
  3. Loobster
    Loobster
    Jan 11, 2005
    639
    28
    +31
    You of course cannot "finalise" a PAL recorded DVD as NTSC. The recorded DVD is whatever the source material is - unless something converts it on the way. Finalisation has nothing to do with what format the video is in.
    You need to look into something that will convert PAL to NTSC.
    --Loob.
