D
dragon1
having got most things up and running now, I am experimenting with Divx, ie downloading from outerspace, then converting to Mpeg2 so I can burn them to a DVD.
can any body tell me if there is a formulae to workout how many Gigs of Mpeg2 I will end up with using diferent vbr's or cbr's during coversion ( I use TPMG so I can chage many of the parameters).
T be specific I recently converted 679Mb of Divx to Avi this gave me 22.9Gb
This I then converted that Avi to Mpeg2 using TMPG with a resolution of 720*576, Cbr of 6000 and 48khz 128 kps sound unfortunately after 3 hours of conversion I ended up with a file of 4.6Gb which obviously wont go on a 4.7 DVD
Is there a rough rule fo thumb I can use before i push the "Oh NO !" button
Dragon
Dragon
