any good
Discussion in 'Projectors, Screens & Video Processors' started by lexus luthor, Dec 7, 2002.
  1. lexus luthor
    lexus luthor
    NEC LT 260 are these any good or should i wait and buy crt
    any advice would be greatly appreciated
    how much are they worth
    thanks
    lex
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,437
    Surrey. UK.
    +2,099
    They seem pretty good by all acounts, but for the same money, you can get a good used CRT and that will give you a better picture.
    Only drawbacks are size and setting up (converging etc).
    The NEC pjs are DLP and can generate rainbow artefacts which a few people see. Many don't but unless you demo, you won't know for sure.
    Digital pjs are dead easy to setup and use - they don't need converging and don't weigh very much much, so can be positioned on ceilings easier and will give a converged image immediately. They're almost plug and play.
    That's a very basic opinion, so I hope that helps a little. :)
    Gary.
