Any good R2 suppliers out there ?
Discussion in 'Blu-ray & DVD discs' started by Cambrai, Mar 6, 2001.
  1. Cambrai
    Cambrai
    Sick of paying over the odds in retail stores for dvds. Does anyone know a good online or mail order supplier out there ?
  2. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    If you mean cheap for good it depends what you want on R2 ? www.hmv.co.uk usually have good 3 for £33 etc and some decent bargain clearances < £10
    Also try www.play247.com (make sure you change to R2 as it defaults to R1)
    I used to use encoredirect but they've snuffed it apparently ...
    Hope this helps ... [​IMG]
    "Hi my names Paul and I'm a dvdaholic ..."
  3. Cambrai
    Cambrai
    Thanks Paul, will check those sites out. Wouldnt call myself a dvdholic yet but im getting that way. Once again thanks.....Mark
