any good micro systems
TellyTel
hi
im looking for a micro system in the price range of £200 - £400
i would like it to be loud but also have good sound quality . i was thinking about a panasonic or a make such as teac.
has anyone any recomendations
cheers
shahedz
gunner84 said:
cheers
do you mean denons like the m31 m35
the M31 exactly, is a brilliant machine, i recommeded one for a freind and we were both impressed with how solid and clear it sounds for an all in one, if you really want the best all in one go for a second hand LINN classik - simply amazing , you should be bale to get oen second hand for about £400-£500, and it really is amazing.
TellyTel
thanks for the replys
is the denon m31 capable of high volumes.
as i want a system that can be fairly loud
cheers
shahedz
it can go pretty high, but really really loud, rememeber you only get bookshelf speakers so it does limite how loud it goes, by all means more than capable for a bedroom or small lounge, again if you go for a second hand LINN you can always add a power amp at later stages so you have more flexibility. but the Denon are supplied with speakers from Misssion, so the speakers are fairly good. but rememeber the size of the speakers and power output will limit how loud it can go, but for a small system within your bduget i persoanlly dont think you can get better than Denon.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
