Any good deals on Tag McLaren AV32Rs?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by jlanng, Aug 20, 2001.
  1. jlanng
    jlanng
    Aug 20, 2001
    In the market for an AV32R at the moment, which will run through a Rotel power amp.
    The best price I've seen so far is a whisker under 2k. I'm quite happy to consider ex-dem or even second-hand, so if anyone's seen any bargains - I'd be ever so grateful if you could let me know!!
  2. gwbailey
    gwbailey
    Tag are doing a special demo evening at the SevenOaks, Liverpool branch on the 20th September, and representatives from Tag will be there. (maybe DR Zucker!)
    So it might be worth your while getting down there, as they might do a special deal on the day!
    It's also free to get in, but ticket only! (check the Tag web site for details!)
    Cheers,
  3. CARLOS
    CARLOS
    Feb 11, 2001
    6,581
    WEST MIDLANDS
    +1,434
    Hi m8
    Welcome to the forum <img src="smile.gif" border="0">
    Don`t know if you`ve looked on Tags own site <a href="http://www.tagmclaren.com/great/sounds.asp" target="_blank">http://www.tagmclaren.com/great/sounds.asp</a> but they do have a second hand section.
    Might be worth a look.
    Cheers Carlos
  4. simoncope
    simoncope
    If you're in the London area, give Karl a ring on 020 8400 5555.
    Alternatively if you're somewhere within reach of Beaconsfield, call Colin or Phil on 01494 681300.
  5. t-force
    t-force
    May 2, 2001
    1,863
    Southampton, UK
    +151
    On HCC's own classified section, there's one for sale, with the THX EX and Pro-logic upgrades going for £1750. If I had the readies, I'd have it by now!!!
  6. Chippy99
    Chippy99
    Nov 16, 2000
    1,378
    116
    Bristol, UK
    +518
    Just make sure any second-hand item you consider buying isn't nicked! I twice tried to buy a DVD32R second hand, and each time the vendors ran a mile when I asked them for the serial number.
    Tag maintain a database of nicked stuff, and they will, quite rightly, confiscate anything nicked that comes back to them for repair.
    Be careful!
    Cheers,
    Chip.
  7. Guest
    "Tag are doing a special demo evening at the SevenOaks, Liverpool branch on the 20th September, and representatives from Tag will be there."
    Graham, I have checked tag's web site but can't find any mention of this. I would be grateful if you could point me in the right direction.
    thanks
