any good amps under £250
Discussion in 'AV Receivers & Amplifiers' started by mkendall, Sep 4, 2001.
  1. mkendall
    mkendall
    Ive decided to buy a amp/reciever for £250 any advice for bargains or recomendations
    thanks <img src="confused.gif" border="0">
  2. jonny
    jonny
    Aug 14, 2000
    224
    16
    Hertfordshire
    There are some great budget amp out there for this price (or a little more!)The yamaha A5, denon 1601/1801 can all be found near this price aswell as other makes, but these are the ones i would consider in this price range as they all have the best reviews and certainly sounded good to me. I bought mine from <a href="http://www.sdb-electronics.com" target="_blank">www.sdb-electronics.com</a> and while there not official english products (european imports)there are exactly the same. I bought the 1801 after auditioning it and its a great amp and not to bad for music either. Mine cost £250 and at british retail costs nearly £400. I think they have an offer on the Yamaha A5 for only £200 which as many peole will tell you is an absolute baragain!These models have now been updated so you may have a little trouble finding them but if you do there sure to be at a good price
  3. jonny
    jonny
    Aug 14, 2000
    224
    16
    Hertfordshire
    I forgot to add that another company <a href="http://www.upgradeheaven.co.uk" target="_blank">www.upgrageheaven.co.uk</a> have got an excellent offer on the brand new yamaha ax4..something! Its meant to be an excellent amp and the service from the comapny is unbeatable, delivery also only takes a day of two!!
    [ 05-09-2001: Message edited by: jonny ]
    [ 05-09-2001: Message edited by: jonny ]</p>
