Any flat panel monitors with S Video input
Discussion in 'Desktop & Laptop Computers Forum' started by uncle eric, Mar 4, 2003.
  1. uncle eric
    uncle eric
    Looking for something to display my OSD/DVD-A menu's etc without turning on my projector. Having looked at the more expensive Sharp LCD tv's and seen the prices £approx £600 for a 15", I thought a flat panel computer monitor (circa £250-£300) might be a better option as long as it can display video and has an S Video input.
    Thanks in advance
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
  3. uncle eric
    uncle eric
    Thanks Paul.
    I'll take a look.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Sounds like you need a small widescreen TFT. There are a few used on the projects on www.mini-itx.com some of which have PC inputs as well. Then you could mount it into a rack could you not, that'd be pretty cool.
  5. WebLoader
    WebLoader
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Eric
    be very careful about connecting a scaler box to computer flat panel display, many of the refresh rates they need to work don't correspond well with DVD player outputs unlike CRT monitors. Try before you buy.
  7. uncle eric
    uncle eric
    Thanks Guys.
    Nic, what I need is to literally connect the SVideo output from my processor to view OSD's and the Svideo outputs of my multi player to view menu's etc. The HD leeza (when it arrives) will go straight into the G70.
  8. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I can recomend the Kiss 15" widescreen TFT that webloader linked to, its got vga, composite and svideo in, very thin as the screen is based on a laptop tft as oppsosed to the desktop tft's that have a better contrast level and wider veiwing angle, I bought it to be able to select music from via the HTPC without powering up the pj and for the other half to watch sky via svideo when she cant be bothered with the big screen and HTPC. I bought mine from Scan for way more than it is now but thats av/pc products for you.
    http://web6.scan.co.uk/Products/Info.asp?WPID=45230
    At £220 + vat its ideal
  9. uncle eric
    uncle eric
    Thanks Webloader and John, thats good enough for me. The Kiss monitor it is.
  10. WebLoader
    WebLoader
    hi john
    i plan to use mine for exactly the same thing, 'casual' viewing of sky+ via svideo. how do you rate the display (currently i am ashamed to admit that my casual viewing when my HS10 isnt fired up is using a ancient 14" portable connected via RF !!)
    have you tried using powerstrip and dscaler on it to see what it can really do?
    cheers
  11. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    I bougth my LCD monitor with s-video, composite video and VGA inputs on a compuer fair off totenham Court road. £265. I highly recommend you check the offering.
  12. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Webloader,
    The picture is okay when its on axis, it just hasn't got a great veiwing angle. Other than that it has all the normal lcd traits with fast moving action but it serves its purpose and looks the part.
  13. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I thought as much and the LCD tv will be fine, however a much cheaper way several have tried is something like the cheopo cheesebox into a computer LCD display. In many instances this doesn't work as the 'computer' LCD has trouble locking onto the 'low' freq. CRTs are fine here. A few have had their fingers burned here hence my warning. The KISS looks perfect, I might have one as well!
  14. JSW
    JSW
    Feb 21, 2002
    4,220
    Staffs
    +301
  15. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
  16. JSW
    JSW
    Feb 21, 2002
    4,220
    Staffs
    +301
    I want the TS version Touch screen ;) would be great for music server.
    Waiting on an email to see if they have stock and will ship to UK.
    Other than that may have to ask me bro's missus in Canada to get for me and forward as a gift ;)
  17. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    Ditto.
  18. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    They will ship direct to the UK.
    See here:
    Hi Richard:
    Thank you for your interest in our monitors.
    Please be advised for UK orders, you can purchase the monitors directly
    to you. Please find below your prices for the monitors you are
    interested in:
    700Y - US$449.00
    700YV - US$489.00
    Should you have any further questions, please do not hesitate to let me
    know.
    Thanks,
    Mike
