AudiophileUk
- Joined
- Jan 4, 2004
- Messages
- 1,722
- Reaction score
- 86
- Points
- 466
Hi all, I wondered if anyone on these boards is a bit of an expert at LCD monitor electronics. I had 2x Hazro W270WC screens. One started to fail and would need to power cycle to turn on... I checked the capacitors and all looked fine. Saw a really cheap Hazro W270WD screen on ebay and brought it (The D model with HDMI etc, but apparently same panel). It turned out the panel had been replaced with some rubbish TN screen.
Now I would have thought I could have swapped the old IPS screen into this model with a working board inside, however both sets of connectros are different! One uses a very small 6 pin ribbon, the other larger 12pin clock (LED lights?) and then the main connector seems to be LVDC vs edp. I can post pics. Anyone know if its possible to convert these?
