S
superaffordable
This is the situation. I have a brand new hi-fi system Thecnics SV80 which also plays DVD in dd5.1 but does not have dts or dp2
Here is a picture
I am quite happy with its performance in both DVD and CD but I want to upgrade for lack of sound formats
I try to sell it but I am having problems doing and I am not prepare to lose on it any more than £150 from new
I will happily keep it while still buying a proper AV amplifier but what I really dont want is having to have so many speakers on the room, so after all the above talk and talk here is the question(s)
1 - Can I take off the centre and rear speakers in the hi-fi and just leave the two front speakers to play CD's without harming the unit?
2 - Still better, can I just get the two front speakers from the AV amplifier (hopefuly good hi spec speakers) and have it connected to both (at the same time), the AV amplifier and the hi-fi, and then play either one as needed?
2.a - Will said hi-fi be able to run a hi spec speakers without loosing in quality and without harming the unit?
Thanks and sorry if any of the questions are quite silly
Here is a picture
