Any experience of Ronin P703 DVD player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Caroline, Aug 14, 2003.
  1. Caroline
    Caroline
    Jul 19, 2000
    169
    Warwickshire
    +4
    My son is looking for a cheap and cheerful DVD player until he can afford a better one. He is thinking about the Ronin P703 which retails at GameLoaded.co.uk for £55.99, allegedly saving £44. It's certainly cheap, but is it cheerful? Has anyone any experience of this machine?
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Ronins are cheap players. Not necessariliy bad but they don't sell for £100 so the retailer is dishonest in its adverts.
  3. Caroline
    Caroline
    Jul 19, 2000
    169
    Warwickshire
    +4
    Thank for the info Bonzobanana. I'll pass that info on. Is there anyone out there who has actually got one of these?
  4. tbibic
    tbibic
    Sep 3, 2000
    47
    :hiya: I have one!
    There's not a lot I can say about it. It does the job adequately enough with no fuss.
    Has played every disc I have thrown at it, even tempremental ones. CDRW, CDR, DVD+R, DVD-R, MP3, raw MPG, normal DVD (!), VCD and SVCD.
    The picture quality doesn't match my Sony 725 - but then I didn't expect it to - but sound quality for DVDs through the digital link was pretty much equal.
    Loadsa comments here:
    http://www.savastore.com/include2/info7.asp?catalog_name=Savastore&product_id=10265005&pid=1
    I ordered from here and though it says "Aries", you get a Ronin! Wouldn't recommend their scarts though - yuk - best off getting a good quality scart.
    Having said all this - I would recommend that your son saves up for the Toshiba 330 multiregion - £80 from amazon.co.uk as it should be significantly better than this player for about £25 more.
  5. Caroline
    Caroline
    Jul 19, 2000
    169
    Warwickshire
    +4
    Thanks for the info tbibic,
    Wow, £80 for a multi-region Tosh 330 is a good deal. As you say, for a few quid extra you get a much better machine. I've got a second generation multi-region Tosh myself and it has been great.
    Thanks again for your comments.
    Caroline
