Hi All,
I have a 4 Lamp Track Light (in my bedroom & directly over my head) which has had 4 x 50watt Halogen GU10 bulbs - this connected to the 240v mains & is controlled by a single GET Ultimate Electronic Dimmer.
Today, I bought some 5watt LED bulbs from Screwfix to replace the Halogen ones but upon fitting them, strangely, two annoying things are happening - one, is that even when one switches off the Dimmer, the LED bulbs still stay on & although it is at a reduced output, it is still enough to distract one when trying to sleep. The second issue is that there is a very noticeable humming/buzzing that is coming from the lamps themselves & it is really annoying. My clock radio in standby even started making the same sort of sound strangely & I had to switch it off at the mains.
The reviews for the these LED bulbs were very high indeed & I do not recall any of them mentioning either of these two issues occurring so am wondering if anyone knows why & how to rectify things?
Would changing the Dimmer Switch do the trick & if so, which out of the many out there will likely solve things? Mine is either a 300VA or 350Va as the GET Brand got taken over by a company called Schneider & they may have changed some specs as I bought mine quite a few years ago. I have found a pic on the net that might hopefully be the exact same or very similar to mine that shows the module at the rear.
If it is not the Dimmer that is causing these issues, then what else could it be? I have attached pics to better portray what I have in case it might help.
On another note, does anyone know where I can get Square MR16 LED Bulbs - ideally with a wide/extra wide beam? My Googling efforts proved fruitless!
Many Thanks,
Suave!
Many Thanks,
Suave!
